spark plug wires
Yup, installed on Jeremys car. He got the blue ones and not only do they look really nice but they transfer power to the spark plug. :eek: :D
They are nice wires though, if I had a fist gen I would get them.
Hey everyone, I like these wires and wanted to know if anyone has had a problem with the fit of these wires? I am talking to visionworks and they said they will not fit a 95 LSC.
Thanks
yeah they fit...just be really really careful with the plug on the coil...and you MUST use the eletric-grease for the plug end or the rubber comes off the end and stays on the spark plug in the bore...
If that happens, put super glue around the wand, and shove it back on the spark plug til the glue sets, and then pull it out..
Also keep in mind they are full silicone jacket...means the coat is VERY soft...use the soft wire holders like I have so you don't cut them
Do you mean die-electric grease? I am pretty heave handed and I have notice that with the plug on the spark plug sometimes they are hard to get off. I tried to get to their website but their site has issues. Do you happen to have a part number?
Thanks
Seth
You know the one thing I fear is that when I go to replace the spark plugs, I will pull the plug to spark plug out like I did before with my MSD wires.
Yea die-electric grease...if you're talkn bout the rubber on the tip of the plug wand...like I said ...put super glue around the edge of it..where the rubber would sit, and then put the wand back on the plug until the glue sets
the plastic clips that clip the wire to the coil break easy with these wires, be careful with them
For not that much more, I would go with the Ford Racing wires, Max has them and they come in red or blue.
