ops lol
is this on your 93?
Don't think first gens have any blend door issues.
Pull the havc out and take a look i guess.
If none of those are the issue, try switching to the floor. If it will blow air on the floor you probably have a vacuum line off of the actuator that is under left side of the dash near the gas pedal. Look up in that area, I believe it is a yellow vacuum line, kinda hard to see. I've had at least 2 cars with that issue.
I've looked around for vacuum leaks too, and not found any, but would stepping on the gas and having it go slowly to defrost then back again once the gas is let up be from a vacuum leak too ya'll think?
check your vac lines under the hood on top of plenum. Bet you find a bad one.
