rear end slide
topher5150
Grand Rapids, Michigan
so i've noticed that when i take curves on the highway at higher speeds and hit some rough patches i notice the rear end shift to the side. is this normal
Eh, kinda. It depends. There is a rough spot on the onramp that I drive every day that has dips in it from where a large transition has started crumbling. Everyday I hit it the rear of the car shifts just a little.
i wouldnt worry about it. you could always fill the entire trunk with quickcrete. even the spare tire area. that oughta hold er down :p
Yeah, mine used to do it too. Larger rear tires. larger sway bar and IRS brace seemed to cure the problem. :)
