ripped camel
So this was happening before Jamie did the swap so it is absolutely unrelated to that.
From a dead stop when I hit the gas (3/4 throttle) the car starts choking like it's trying to stall and acts as though it has only 10% power. For whatever reason if I floor it when this happens it stops doing it and after that seems to run better. I have no clue what that is.
So far here is what's been changed (keep in mind this problem was there before any of the following were added, I'm just listing the things I've done so we know what it's not):
SVT 255lph Fuel Pump
98 trans swap
Mercon V full flush and fill
Mach 1 torque converter
New spark plugs
IMRC's cleaned (however I'm getting a Cel that they are stuck open)
Checked and replaced all coil boots
PCV
crankshaft position sensor changed
As usual search doesn't net any results and I've spent hours looking this up....
98 trans swap
New spark plugs
PCV
