Tuck that wiring up behind the headliner by the windshield and then it'll be clean. I like it, though![]()
my responce took alittle to long...i dont know how much give the ls's headliners have..thats alot of wire to tuck..
There is a gen1 ls across from you in the first pic.
I would also say to tuck the cord away. If you want to move it just pull it out, it's not like it will be permanently stuck there. What brand is that?
I would have just put it up in the visor and ran the wire down the A pillar and wired it to an on/off switch so I can hide it if I actually DO get pulled over... while completely legal in most states if the time arises if you actually do get pulled over nothing says "screw your warning, give me a ticket!" like a big 'ol radar detector in the middle of your windshield
JIMO
damn good catch eagle eyeThere is a gen1 ls across from you in the first pic.
it's not in the middle of the windshield....in fact you can barely see it from behind, front or side of car
and your gonna be hiding a detector while 5oh is coming up behind you...oh...that doesn't look suspicious at all...you'll be lucky if you don't get pulled out of the car and givin the ole 'Give that yaig a pat down'
just don't speed, lol
::sigh:: you don't understand...
the radar detector is already hidden regardless if there is a cop behind you or stuck in a ditch in oklahoma... I've done this kind of thing before... the only thing you need to do is turn it off via a toggle switch... otherwise you cannot see it at all, the sound gives it away from above your second visor when cops are present and all the wires tuck cleanly away down the A-pillar... that is all you need, so why keep it in a visual place? my passengers never even knew I had one until it went off
I can also tell you how the splice a button that will go to the fuse box and shut off the data logging for your mileage so your odometer never goes up if you want as well
