As the title says I am having some battery issues. Last month I replaced the alternator then after that everything was fine. The problems began last saturday, I was driving fine made a few stops. I go to start the car and it kind of choked as in when the battery is weak. So I go home the following day the car starts the same way but it drives fine. I then put the volt meter on the car it reads at 12.3 while running I say ok let me go to autozone get a new battery. I did and it was still reading at 12.3. Last night was when the major issues happen the car started to make a low hum battery light and abs light came on. I turn off the head lights and park put back on the volt meter its reading at 11.5!. So what could it really be? Do I need a new alternator? or new battery cables? I am going to check to see if it could be the alternator fuse. Also wanted to point out one thing when I checked the battery this morning it only read 12.0 not 12.6. Maybe I have a parasitic drain? Thanks
