question about the VIII
lloydrage
USA
I currently own a LSE and I am thinking about getting a Mark VIII, my question for you is what are known problems with the car?
I am hoping to get one with less then 80K miles on it, any advice is appreciated
Gen 1- 93-95
Air ride issues.
Transmission is weak but can be upgraded with a j-mod or install a 98+ transmission with a re-pin.
Headlights suck but can be re-chromed and a aftermarket HID kit installed.
Whole front end will be shot around 100,000, about $500 bucks in parts to fix.
Have to have a chip programed... OB-1... if you do any mods.
Gen 1 96
Is upgraded to a OB-11.
Still has all the other gen one issues.... plus more... it has parts that are used for only this year.....a bastard child.
Gen 2 97
Air ride issues
Same weak trans.
Blend door issues "no heat"
Headlights can go out, but an after market HID kit will fix.
Rear neon will go out, about $100 bucks for a glitch that will fix it.
Most 97's black cars will have clear coat issues.
Gen 2 98
Same problems but has a upgraded trans.
thanks for the info!
Depending on price I would still go with a Mark VIII, I was trying to choose between a foxbody and a Mark VIII, and so far thinking 8
the 79 fox body was 80's
so were the 90-93...they even put skirts and mullets on the 90's foxes
soooo 80's
lmao
line up a stock fox and a stock mark 8...lol
especially if you line up a 93 mark against the 93 gt.
pwnt...
If you want cheap to mod and fix get a fox body, it's basically a blank canvas. There's almost nothing that can't be done to a fox. If you want something unique get the Mark. If you want the engine of the Mark with the modability of the fox get a 96-98 Cobra.
98 swap doesn't require a re-pin only a harness swap. A few of us have done this now.
Ummmmm, and you used a hammer on you valve cover, and your having Dr. LSC do a motor swap on your Mark?!?!?!
Confusious, says........ man standing on toilet is high!
Please explain yourself.......................
BTW, 1979 - 1993 Mustangs are, Go Karts (I don't mean that in a good way), and very very 80ish!
Dr. SVO phd
Best fox cars I ever had were '87 and '88 T-Bird Turbo Coupes. Both were 5-speeds and both were fantastic cars. Powerful, fast, great handling, comfortable, quiet, and great on gas. I miss 'em both.
Dr. SVO phd
I don't think he understood what I was saying by a re-pin.
There is more then one way to skin a cat. :shifty:
