LaserSVT 98 White Pearlescent Progress Thread
Yeah I hear they help a lot. I am working on something else now though so they may get delayed a bit for this other thing I want...... Oh look! A squirrel! *chases butterfly*
So anyway I took some pics today. :D
And why my job is better then yours. :p
I'm gonna start parkin mine in front if your door and walkin home, hoping you'll get bored and wax it
Oh good, now I have somewhere to sit while I smoke outside. :D
*sits on hood*
*hears a distinctive crunch*
Today was a tweak and tune day for me. I noticed that the passenger front wheel bearing had a tiny ammount of play so I swapped it before it became an issue. Also swapped out the passenger rear caliper slide pins. SVO pointed out that one was frozen and he had assumed that it was his fault. It wasnt. After using an air hammer to knock it out I saw that it was dry so I must have forgot to lube that one. :( Its all good now though. :)
I also went to index the drive shaft and the 4th bolt turned out to be my enemy. Snapped my ratcheting 12mm wrench and then started to bend my other 12mm wrench so I gave up cause I was running out of tools. :lol: Figured I better put the other bolts back on before I snapped my last 12mm in half. :(
Woot woot! Parts on teh way! :banana: Brandon should have my seat out tomorrow and I ordered my exhaust pipes today. My custom tips showed up and man are they nice! Double walled rolled tip, slant cut, intercooled, polished stainless, 2.65" inlet and a 4.5" x 3.25" opening. :wrench
You didn't take pics of my feet while I indexed your drive shaft ? :-(
Moar progescionses.
I went on a spending spree!!! :wrench
Ordered the Addco 1.25" sway bar, engine cradle brace, IRS brace, Magnaflow X-pipe resonator and my Borla Pro XS mufflers. :wrench
Also my new tires showed up today. Wish I was at my office instead of running the Corsicana one so I could go have them installed. :(
So she goes back to the body shop on Monday and get her back Thursday and then it will get the tires and on Friday it will get its exhaust done. Work work work! :lol:
I decided to try and carve up the lense and make it fit. :)
OMGWTFBBQ!!!!! I could freakin cry! I am short by $600 right now. :( I just spent $1000 on Friday for all the exhaust and braces and sway bar plus the deposit on my new tires. I could have waited on all of that and bought that now. I couldnt have afforded injectors and such but damn thats a good blower..... I need to figure out a way to do this.... maybe .... hmmm, gotta sign up over there.
So I got the new part installed but still have to wire it into the car. I have the USB, bass knob and defroster hooked back up and I also have the wires run for the ASHAM just need to cut the air ride harness. Ran out of time today so will have to wait till next weekend.
Also got my exhaust pipes. Sure are pretty. :D
Before:
After:
And my new pipes.
