Yes, you did a great job of venting to the outside.
Thanks
Here's the pic:
regardless, i need to find that vent tube. anyone have a pic of it and it's location?
Unusual conditions such as the failure of the voltage regulator or the voltage sense line to the alternator? Rare, but it does happen. Crashes are rare too, but you still have seat belts and airbags.
That's some fantasy you have going there...
Yes, it's a one-in-a-million sort of thing to have happen. However, if you're that one, it doesn't matter how low the odds are. Save $10 in exchange for the very slight risk of a very painful death. That equation works for you, but it doesn't work for me. I guess it's a good thing that you don't design this sort of stuff for a living.
... I would say it is barely plausible. Just an opinion, of course.
I think it is safe to say, unless you are throwing your battery on a charger and sending a 16 volt trickle charge to it overnight. You are fine.
The top of the photo's is the passenger side and the right of the photo's is the end of the car:
It is extremely rare for your alternator's regulator to fail. And even more rare for it to fail and 'overcharge' instead of undercharge. And even more rare that any expelling of gas out of a dry cell battery would amount to something that would 'cause an explosion in the cabin'. And even more rare that it would vent gas at all. It takes massive overcharging to screw up a good quality dry cell battery.
I have seen the results of overcharging dry cell batteries and it is not pretty, but there was no explosion of any sort. And it only occurred from overcharging, on purpose. In car audio competitions you need all the voltage you can get, and people push these batteries to their limits and then some. Professional shops also install these batteries inside cabins of cars and vehicles used for daily driving, in addition to competition vehicles. It is not rare to see batteries inside the cabin of a car. What IS rare is a dry cell battery killing you because you don't have a plastic hose connected to it. I would say it is barely plausible. Just an opinion, of course.
thank you very much for the pics, it really does help, but at the same time i see that i'm screwed since i'm positive i used the dynamat right over that spot. do you know if they sell the hose by itself?
It would probably be easer and cheaper to find hose at a home improvement store. I know both Lowe's and Home Depot have different size hose sold by the foot.
classic case of Darwinism!!
What typically happens is a simple spark will cause the hydrogen gas to explode, not your alternator theory of overcharging.
Do us a favor and caulk the trunk shut and then post the pictures when the car explodes.
hey douch-drizzle, go back and look at the OP. This did not start off as a dry cell battery question.Oh wow, I know all the controversy on this forum about using the stock/vented batteries etc, but I cannot bring myself to pay 100 dollars for a standard wet cell battery. Just an opinion of course.
Does it work well?
It is extremely rare for your alternator's regulator to fail. And even more rare for it to fail and 'overcharge' instead of undercharge. ...
