I just had my engine and trans swapped, i now have: easy entry data error, reverse mirror data error, drivers glide data error. i did a few searches couldnt find any info on those errors
also the abs light and tration control off light is on, message center says check traction control.
the car repsonds much better than before braking is fine, except when i was parking and slide on a patch of ice, i didnt feel the brakes pulse to adjust for the lost of traction.
im going to check the abs relay, then ill clean the sensors and check the gaps. hopefully they unplugged them when they took my front end apart and didnt strecth them out and break them internally.
what else should i look for to remedy my abs/tc problem.
thanks for any help.
