2000 Ls Kit
GSXRDUDE
So Cal
90 bucks, put one on a few weeks ago
I don't think thats his car, its just an add for the intake? I could be wrong, it sure is a fugly bay either way.
His car is light blue. Will a KNN typhoon heat shield work on a gen1? If the bolts dont align you could just drill some
can't tell from the photo - how are the connections for the IAC and PCV setup?
I had seen this on ebay. Is there a heat sheild that would fit this? Does anybody know if the one from LS Koncepts would fit without drilling holes?
that "heat shield" is not really doing anything
Sure it is, it deflects ash, spilled cocktails and assorted muck from the filter when I am :q:q:q:qfaced and try to work on the LS. I have small scoop by the fog light and the hose runs up to the hole where the stock airbox was. The engine compartment is blocked off at the MAS so the shield keeps that air arround the filter longer and helps to push hot air out. I hope.
