jolinc01
I have some heat issues with my 01 V8. I think it's the aux pump, but want to test it before I replace it. Any help?
it is - you can feel it on, and hear it - although if it is full of coolant, it is very quite.
sorry to bring this post up from the dead.. but I am pretty sure my pump is bad as well and I am currently downstairs doing some troubleshooting on it. Does anyone know if the PCM commands for the pump to turn on any time the engine is running at idle? Or does it command for the pump to turn on after the engine is at full operating temperature? When should I see 12v at the pump?
All you guys must be motivated. I saw all the crap I have to pull off to even touch the pump so I just shut the hood.
I am dealing with luke warm air in single digit temps, haha.
Just an update. My aux pump was not bad! For some reason, the climate control system is not sending voltage to the relay to engage it, so the aux pump was not receiving power. For now I have jumped the relay so that the aux pump is on anytime the ignition is on.
And the heat feels great now!
Thanks for everyone's help!
It seems like that should be an acceptable permanent solution, unless it causes the pump to wear out too soon.
