cannons_custom
Is there a way to overide the safety that only lets you start in 2nd? What if I want to start in 1st?
Is this for all years? Mine starts in 1st and shifts down to 1st when I stop on while on a gear above 3.
It's not a "safety". The 2nd gear start in SST was to avoid the gas guzzler tax. Mash the peddle and you'll get 1st. Specifically, you'll need >60% throttle.
Could it be cause I am taping it rather than just dropping the pedal down?
If I get on it from a stop and hold it it don't always go to 1st though.
I know it does this cause if I really wanna rip on it I like to keep the throttle at mid range rather then hitting it to the floor.
But like I said, its not 60% cause I like to keep it at mid throttle so I can keep pulling rather than wast gas going nowhere. Could this be a problem with my trans or maybe something the dealer did when they did the flash update?
When I tap it I do it just as a light changes so I can take off in that gear from a stop.
no - the Gen2 was more fuel efficient (mostly VVT), so it could start in 1st without failing the CAFE rules.
Alright!!!.. You gen 1 guys get to rev your engines without our throttle by wire and us gen 2 guys can start in first.
What do you have now instead of that filter?
