SATURN5
Dr. Frankenstang
First, I'd like to say hello to everyone. Been lurking for a few months while I was searching for a Mark VIII. I finally found a very nice 96 base with 112K miles, with new struts/bags/compressor (Arnott), drilled and slotted brakes, and a upgraded trans with shift kit/stall.
Had it for a couple weeks now and I'm getting the dreaded check air ride when over 60. Searching leads to a stuck vent solenoid as being the likey culprit. I've manually checked the compressor and valve by disconnection them at the 4 pin connector and applying 12Vs to each. The compressor runs, and the valve seemed to open.
I plan to contact americanair for a spider valve setup, however I did notice that the 4 pin connector is corroded somewhat. I cleaned it up (both halves) as best I could, but I would like to replace both halves if someone knows where I can source replacements. If I can't get the original type, I'll go with a high current 4 pin weatherpak.
Second question is the tach is not functioning correctly. The needle turns counterclockwise as rpms rise, then settles ~1K while driving.. Ideas?
Anyways, love the site and all the info... Been keeping me busy reading, just ask my wife...
Thanks, Bob
Thanks, Bob
