I'm running B heads without an intercooler so i'm not sure what your pointing out to me there. The snout of the s/c wasn't getting as hot as the main body, but i'll take a temp of the alt next time i drive it very far. The snout is actually the exit point for the air though not the intake, so i'm not sure that it's going to have much of an effect on the iat. Kenne bell can SUPPOSEDLY tell exactly whats wrong when they tear them down and i've told you their findings. The first thing they asked me was if I had an open air filter. When i said yes it automatically voids the warranty. So, I'm going to correct the prob regardless and if the seals go out again I should then be able to argue the point with them. When i get it back it shouldn't take long to see if the cai fixes it cause I drove it less than 400 miles before it waxed the seals.
My actual post was to see if anyone had an intake or snorkel system for a cai, not argue this point because i'm in their world now and its really up to them. Driller got me a website and i ordered some piping, although I might just try putting the stock intake behind the hl into the box i've built for the filter first and see what that does. I'll get some temp readings on it and see if it helps. My iat's were 217 degree's on my last dyno run. Kenne bell says that 130 degree's is the max intake temp acceptable before it causes prob for the seals, so right now that's my first goal. Only time will tell if it fixes my prob. Thanks for the help.
