PetesSweets86
I wouldn't say that, but the one steve is selling has already been installed, and he can tell you all the little things he did.
certainly couldn't build a new kit for that.
indeed indeed
To briefly revisit the 4.6 swap discussion, McLaren prototyped two Gen1 cars for Ford. The major change necessary was to re-design the intake manifold so as to clear the hood. A small run of 4.6 manifolds was cast from magnesium with a lower profile so it was unnecessary to cut the hood. Since the work was a feasibility study for space, I doubt that they bothered to hook-up all the bells and whistles. I saw these cars, far along in the necessary fabricating, during some business at McLaren. And please have no doubt that the Ford Engineering folks are capable of completely integrating the electronics. I am, at present working with SCT to determine the limits of their ability to 'bend' the factory stuff to work with slightly different hardware.
One Lap was a too-close-to-last-minute operation. 'Burning' a new program to recognize the hardware differences isn't a five minute operation, but it's certainly factory-do-able.
I don't think i need a pro race kit. I should be able to get another 100hp out of the Venom kit.
Does the SCT tune address any of the air speed issues?
Or you can go clear to the point of substituting methanol for the gasoline, and installing a complete separate fuel system. (See "Land Speed LS" in the performance section.![]()
KS
I see what you are saying. So what kit did you use? An NX? What are the power gains off a 100 shot? I'd say i would probably want a Progressive 100 wet shot right?
I ran a NX 20922 - just a universal wet kit. The shot size is roughly the rwhp gain. I did not use a progressive controller - and blew the tires off of it constantly, so I would add one if I was ever to do it again.
couple of other items to think aboiut if you do this:
- always run 93 octane
- swap in colder copper strap plugs (typically 1 degree colder for every 50hp you add)
- get a wideband - I use an LC-1 from Innovate Motorsports
- you'll need a SCT tuner and a proper tune
