Why would there be oil here (driver's side)?
lsintoronto
Toronto
Why would there be oil here? Around and leaking from front plug on driver's side.
2004 LS8 with 64K miles
that is a commonish problem with the Gen2 - oil seeping from the VVT solenoid.
A new o-ring seal. I think it was about $100, installed, at the dealer.
$100 is cheap considering you have to pull the valve covers - or can you do it without? ....
I had the car in at the dealership yesterday for a `maintenance package` (glorified oil change but wanted a few things checked out on the car - forgot about this one until today though) and brake fluid flush.
They did not mention this oil though and it`s obviously clearly visible. I`ll have to email the service advisor the pic and ask about it.
Do you think it`s easy enough that I can fix this myself when I replace the spark plugs soon
Yes, I'm pretty sure they had to pull the valve cover. However, they didn't charge for new valve cover gaskets, just the one o-ring and one hour labor.
