What'd you use to fab these?
3/8" chrome steel rodends, chrome threaded stock, nylock nuts and 2 3/8" bolts. the best part is that i can adjust the angle of the links when i lower the car to maintain the same angle between the frame and the bar.
real slick... it's hard to tell from the picture, did you use thrust rated Heim joints or the standard ball joint Heims
also I hope you used a quality threaded stock... I'm sure you did though
and how you really gonna test it?
Come on out to South Bend, IN. We can see if we can get you on the TireRack skidpad.
In regard to 'sway' bars, is someone in position to be able to measure the existing ones? By that, I mean to not only the bar diameter but lengths of such things as side-to-side, the lever arms on the ends and the angles the end arms make with the center portion. Also differences between the front and back. The info will make it possible for me to make alternate suggestions.
KS
Think it'll be open on the Power Tour this year?
i'm in Lansing, MI not that far, that would be a blast.
its tomorrow.... wheres the parts?
anyone running an eibach pro kit? lemmie know wacha think about the handling.
