AbrahamLincoln
Okay did like 10 pulls on the dyno today if not more.
1. Base tune on car not heat soaked it put down 237whp! Was able to lock it up with the sct software in third.
After that it fell to about 223 or so after it got heat soaked.
2. New best 254whp/255 tq
then did the spray, i think the personal best was 347whp and that was with timing pulled a couple of degrees. I don't have the sheet for the spray, my pedel switch had to be adjusted and the bottle temp was fluctuating, i think the 347 was at a little under 900psi
this was with autolite 274 gapped at a lil over .054. Ill post the dynosheet when I have my scanner all hooked up.
