Missing Linc'
Can anyone tell me if the Gen 1 V8 and Gen 2 V8 intake manifolds are interchangable?
I would assume no, but then again..I'm 100% wrong 99% of the time...1% is when I'm masturbating...cause then I'm RIGHT
I dunno, the heads on the Gen 2 have that VVT stuff. Although that wouldn't necessarily mean the ports are different, I think they would be different enough that it wouldn't work without some reshaping.right - the ports should match - however - lots of work moving all the connections - intake, throttlebody, egr, vacuum, throttle cable....
Why do you think the power/mileage is better in the gen2 vs gen1.
who was this for?
throttle by wire, no air assist fuel injectors, different intake and exhaust mani, different gearing.... yeah the two arent the same car at all!
Well I never had been in or known too much of the Gen2 beyond just looks and the eletronic Ebrake and the change in engine.....but as you explained...much much more......
