JWerner2
- Joined
- Mar 27, 2008
- Messages
- 4,934
- Reaction score
- 2
Didnt Canuck give the largest amount of drop but they stopped production shortly after starting?
link for purchase?
Are you selling them ???Springtech. I have a set boxed up in my garage. They give ~1 3/4" drop.
Springtech springs
I thought you also had your car on Eibachs?
Awwwwww man!~ My mistake! I wanted to so those wheels on a lowered LS.
Springtech springs
If you don't go aftermarket, get some 20mm spacers. That would look awesome if you pushed the wheels out just a bit.
See this thread:
http://www.lincolnvscadillac.com/showthread.php?t=43680
FYI Repete, the rear camber cannot be adjusted. Any negative camber will stay that way. Running lower tire pressure will help to slow down the uneven wear on the tires.
Really? I have read that it cant be adjusted in the rear. Unless its just the fact they dont have kits for the rear. I did read on other sites about some cheap ways to adjust camber with washers and longer bolts. Wasn't sure if it would apply to this car.
Hey thanks guys. I am pretty happy with the way the stock wheels look on a lowered LS. The only problem is that the chrome on the wheels is starting to chip off and I'd like to replace them with something a little nicer.
LS4me your car looks awesome with those wheels.
