Just lowered 04 LSE
StealthLSE
Woburn, Mass
I put in the Eibach Pro Kit and OEM sport shocks. I did them myself and it wasn't hard at all. The handling is wayyy better now. Now I can't wait until spring to put some 20s on her. :D
That looks good! IMO dont kill it with 20's!
The LS looks great low on those type of stock wheels!
Either I'm still high from last night or your rear ball joint look worn....the rear wheels look a bit warped......
??? who's wheels? The OP's? That's way too small of a pic to determine if a wheel is warped.
Its called camber, it is what happens when you lower a car. It is also a slight illusion do to the camera angle.
FYI Repete, the rear camber cannot be adjusted. Any negative camber will stay that way. Running lower tire pressure will help to slow down the uneven wear on the tires.
true
btw, would you suggest spacers for when I'm putting on 19s? Spacers weren't mentioned by my dealer when we discussed throwing on 19x8.5 wheels
If the offset is over 50mm, spacers would do nicely, although not NEEDED until you get into the 60mm offset range. That's where the LS stock wheels sit.
No, not if your running a low offset.. Typically spacers around these neck of the woods aren't liked,... well until recently anyway:rolleyes:
Dealers dont usually think of those things, most people dont understand how ugly wheels look pushed so far into the wheel well.
dont go with 20s. those wheels look so good on a black ls in my opinion (the only thing that would make them better is if they were the 8 spokes).
My only problem with those stock wheels is the widths or I would have a set over the ones I have now.
:confused: They are huge, probably have sets for just about any car out:D
nice look are eibach springs only available for the ls been looking cant seem to find anymore???
ARe you asking if Eibach's are the only springs available for the LS, then no. There are:
Eibach
Intrax
Sprint
You know, I dug up a ooooolllld thread the other day looking for the ID of our springs and I found that at one point there were other companies available?
