slabls
throttle body assembly location anyone?...
the EGR hoses connect to the throttle body (that's how the recirculated exhaust gases get back into the incoming air) and the little machined orifices were partially clogged.
think of the baby seals.
plus you have to knock out the EGR with SCT our it will throw a CEL...
Okay I feel bad bringing up this topic again but I need help.
Today I had to remove my Throttle body and the manifold that it connects to so I can replace some coolant components and the Thermostat housing.
when I was removing the parts the 3 way little Vacuum lines attached to the EGR and the manifold crumbled.
By chance does any one know the part name/number or where i can get one from. I been searching the net for the past 2 hours with no luck. Any positive input would be appreciated. Thanks
As seen in the picture the broken red tubes are what i'm talking about.
Okay thanks I'll try that.
