topher5150
now that i got the cobra intake on, every thing hooked up all of the hoses put back on. and now the car won't run for more than 10 seconds
Try burping the fuel rail and crank again to make sure you have correct fuel at the rail, can you hear the pump run? Even with a vac leak it should still try to run alittle more than that. Also try plugging vac lines and see if you can get her to run but watch that the idle doesn't take off on ya.![]()
