Ford racing plugs & 764s Big Difference!
The Rev
Providence
I just got my 9mms from Max yesterday, so I installed them and the 764s (gapped to .054 cuz I'm pretty much stock, I heard thats the way to go?) and man what a difference. My 93 has 116k and still had the factory wires. I was getting an average of 13 mpg mixed highway and city, so I did a test. I drove 40 miles before I did it, 20 highway and 20 city, and averaged 13.2 on the trip calculator. The same trip after the install showed 18.7 mpg, now I didn't go over 70 on the highway or over 35 on the city streets to get a better reading, but man thanks max. Now i just need to buy 9mm grommets since they're tough to squeeze into the 8mm ones
I also just put 764s in and wow no wonder why I only ran a 15.2 in the 1/4
now it will break the tires loose from 1-2 with no problem the bosh 4s that were in it looked like crap
no? im pretty sure the ford racing guy on the phone told me they are manufactured by MSD. 9mm? right
i still can't make up my mind on spark plug wires. btw about the 764's thats what I am running with my tune and yea I felt an increase in power with them over my one step colder 103's.
It is contrary to what this says: ill leave it up for more discussion.
"SPARKPLUGS 101
����������������������� ����������������������� ����������� ���������������� By A-Train
INTRODUCTION
There has been a lot of talk on the subject of spark plugs and there is a lot of confusion and misinformation. I wrote this report up to help you pick the right spark plug for your application and understand why. This report may or may not affect your application.
Lets start with a spark plug. As you know, a spark plug is the device that is used in an internal combustion engine to ignite the air fuel mixture in the combustion chambers. A spark plug is threaded into the cylinder head and protrudes into the cylinder area. It normally has two electrodes which project into the combustion chamber (cc). When the spark ignites the air/fuel mixture, the energy expands and forces the piston downward. The ignition system (which I won't get into at this point) on the 4.6L is either a DIS or E-DIS system (electronic distributor less ignition incorporated into the later EEC-V computers). High voltage is passed from an energized coil pack, through spark plug wires and to the spark plugs. There are a few exceptions to this.
APPLICATIONS
1991-1997 4.6L Crown Vic/Grand Marquis uses spark plug wires
1994-1997 4.6L T-Bird/Cougar uses spark plug wires
1996-1998 4.6L Mustang GT uses spark plug wires
1993-1997 4.6L 32V Mark VIII uses spark plug wires
Of course there are the Town Car and the modular trucks as well.
Ford eventually went with the coil-on-plug ignition system for their newer cars. The first production Ford to receive the coil-on-plug system was the 1996 Taurus SHO. The following vehicles received coil-on-plug as well.
1998-present 4.6L Crown Victoria/Grand Marquis
1999-present 4.6L Mustang GT
1999, 2001, 2003 4.6L 32V Mustang Cobra ('03 supercharged)
1999-present Lightning 5.4L supercharged
1998 4.6L 32V Mark VIII
There are others on the list, but I feel that covers our topic range. So moving on, regardless if the system has spark plug wires or not, it still has coils and spark plugs. The energy released by the coil is sent through the spark plug to the electrodes. The current then arcs or jumps the gap between the center electrode and the ground electrode. This ignites the fuel vapor in the combustion chamber. It is possible for the coil to release up to 40,000 volts or more. The higher the voltage, the hotter the spark. The hotter the spark, the better burning it will be and the more power you will make.
There are many different types of spark plugs. From retracted gap/tip, regular gap/tip, cut back ground (used in some NASCAR applications), fine wire electrode, medium wire electrode, projected nose, and surface gap. I'm sure I left a few out. Now we are going to talk Motorcraft spark plugs and applications.
Stock 4.6L engines normally use a AWSF-32 plug in either Copper or Platinum. This is a nominal range for all purposes. The AWSF prefix letters tell what type of spark plug it is, or it's family. Normally the prefix tells the thread length, the type of taper, the suppressor type, etc. If you are interested in the exact meaning of each prefix, pick up a Ford Motorcraft spark plug specification book. Moving on, the number is always the heat range. AWSF-62C would be a hot plug. AWSF-2C would be a cold plug. I will get into heat ranges later on. The suffix in the part number is the type of material the center electrode is made of and/or the ground electrode. AWSF-32C is copper. AWSF-32PP is platinum (platinum ground and electrode). Most early 4.6L engines used copper spark plugs which are fairly standard. First, copper is readily available and cheaper than other materials.
IGNITIONS
Let me explain the DIS ignition system now. The Ford DIS/E-DIS system works on a waste spark management. One half of the spark plugs fire from the center electrode to the ground electrode and the other half fires from the ground electrode to the center electrode. The EEC fires two spark plugs simultaneously. One spark plug on the compression stroke uses the majority of the coils stored energy, the other spark plug on the exhaust stroke uses very little of the coils stored energy. This is the reason why you see two numbers for each sparkplug on the coil packs (i.e. 7/6, 4/1, 2/3, 8/5). Those two spark plugs are connected in series and this is the reason why you found AWSF-32PG and AWSF-32P plugs in your 1996 and later 4.6L vehicles when changing spark plugs. Only half of the plugs will wear out faster than the others. Ford only needed half of the spark plugs to be full platinum, so this was done to save cost. The replacement for these are AWSF-32PP, or 8 double platinum plugs. Later on Ford changed their suffix designation on the platinum plugs to "EE".
MATERIAL TYPES
Materials used for sparkplugs can dramatically alter longevity, efficiency, power, and even knock sensitivity. We will discuss three types of materials used today to manufacture spark plugs. The first is Copper, which is becoming more and more expensive.� Copper melts at 1981 degrees F and that makes it suitable for an internal combustion engine. It's a great conductor of electricity (second to silver), heat and can resist corrosion to a point. Copper is very soft and can be easily drawn into wires. The majority of the spark plugs on the market today are copper since it is the most economical of the material to use. Nickel is also used as an alloying material for a copper spark plug. However car makers have be using platinum plugs in their engines to increase the tune-up intervals.
Platinum is a precious metal and it is rare, that makes it more expensive than copper. It melts at 3,200 degrees F. and it is highly resistant against corrosion. Platinum has a high fuse point with high electrical resistance. It is also harder than copper, making it very useful for longevity of a spark plug. Make no mistake, copper is a better conductor than platinum.
Finally we will discuss Iridium. Iridium, is extremely hard and brittle material and extremely rare as well. The melting point is 7,466 degrees F. and it is considered the most dense of elements. Iridium is used solely as an alloying material for platinum. Platinum alloys contains a small amount of iridium which is much harder than pure platinum.
HEAT RANGES
Heat ranges of a spark plug are often misunderstood and neglected. The term heat range refers to the relative temperature of the core nose of the spark plug. "Hot" and "cold" terms refer to the thermal characteristics of the spark plug or the ability for the spark plug to remove heat from its firing tip and combustion chamber. A cold spark plug transfers heat faster from its firing tip into the insulator. This is due to the shorter insulator nose it has. That helps keep the tip of the plug from glowing red and accidentally pre-igniting the air/fuel mixture. The heat is transferred into the cylinder head and engine coolant. A cold plug is used on high compression engines or extremely high cylinder pressure situations (i.e. superchargers, nitrous, or turbochargers). A hot spark plug transfers heat from its firing tip, slowly. The hot sparkplug is used in a low compression engine to avoid fouling since the combustion chamber temperatures are low.
It is important to remember that a spark plug does not make heat, it simply removes it acting as a heat exchanger. The way the sparkplug companies control heat ranges is to normally vary the length of the core nose or the alloy of the material used in the electrodes. So a hotter plug will have a longer insulator nose and therefore a long heat transfer path. Cold spark plugs have a short insulator nose and can transfer heat much faster. A cold plug reduces the chances of knock, making the engine less knock constrained.
The trade off is fouling. A colder sparkplug is prone to fouling faster than a hotter one. Let me explain why. A spark plug must reach a certain temperature for it to burn off any carbon in the combustion chambers. Also the same applies to fuel. If the plug is to cold, it may not reach it's cleaning temperature during normal driving and that will cause the plug to accumulate deposits. If the deposits aren't burned off, the chance for a misfire or when the air/fuel mixture is not ignited properly or at all, can occur. Since a hot plug retains more heat before transferring it to the engines cooling system, it can burn off these deposits more efficiently. Likewise, if a spark plug is subjected to extreme temperatures that exceed 1,000 degrees C., the spark plug can blister and sometimes melt. Just so we are clear, the heat range of the spark plug has no effect over voltage or resistance required to jump the gap.�
�The rule of thumb is if you beat on the car and go to WOT (wide open throttle) often, you can get by with one heat range lower. Motorcraft offers an AWSF-22C plug for this. You effectively dropped one heat range colder than stock. If you have no modifications that warrant a colder plug, you will not benefit from them. If you run a supercharger or nitrous oxide, you want to go as low as you can with the heat range without fouling up. The '99-present 5.4L supercharged Lightnings use a spark plug two heat ranges colder than stock. The '99-'00 Lightning used a medium platinum wire electrode plug with full threads. The part number is AGSF-12EE. I believe the AGSF-12EE plugs have been superceded with the newer plugs that I'll talk about next. The '01 to present Lightnings used a newly designed sparkplug with a fine wire platinum/iridium electrode. The part number is AGSF-12FM1. Again it is two heat ranges colder than stock in the AGSF family.
If you are running more spark advance via a custom tune or chip and you have a few more advanced modifications, drop two heat ranges colder than stock. If you are running a supercharger or nitrous go with AGSF-12FM1 plugs or AWSFA-12C plugs. The AWSFA-12C plugs are in the AWSF family. They are two heat ranges colder than stock, medium wire electrode and copper. These are excellent for performance and very reasonable price wise, even when you are changing plugs often (which you should do).
Now, the 32V Mark VIII (DOHC) engines have knock sensors from the factory. The EEC essentially listens to the engine for harmful knock. Since the onset of knock is lower than a human can ear, the sensor pulls timing out before you even know anything is happening. So as a very wise man once told us, these engines are already knock constrained from the factory and are pulling timing even with premium gasolines with higher octane ratings. So switching to an AGSF-12FM1 or an AWSFA-12C plug reduces the chances of knock, therefore the EEC doesn't get a chance to pull spark out. The result is you gain back lost power and a good amount of it. The plug itself is not responsible for more power, the spark advance is. Most of the 4.6L SOHC 2V engines do not have knock sensors so this doesn't apply.
GAP
The term gap means the area between the center electrode and the ground electrode on a regular type of spark plug. The gap setting on spark plug is critical in efficiency and power production as well as emissions. All things being equal, the larger the gap, the more power you can make. Provided the spark can jump the gap between the electrodes. If this does not occur, you have a misfire or a dropped cylinder. On the 4.6L 2V engine, the gap should be set at 0.054" with a stock ignition. That means the space between the electrodes should be fifty four thousands of an inch. Always set the gap on a new spark plug when you take it out of the box. They are normally not set to your vehicles specifications and if not properly set, you will suffer in the performance department. To determine your specific gap requirements, either check the VECI sticker under your hood or consult with a Ford Motor Company or Helm service manual. Use a feeler gage or gap tool to adjust the gap.
Now on a supercharged, nitrous oxide injected or turbocharged engine, your cylinder pressures are much higher than a naturally aspirated engine. As cylinder pressure increases, the energy needed to jump the gap between electrodes does too. Unfortunately, the stock ignition isn't powerful enough to provide the additional spark voltage required to jump the gap. Effectively, you are blowing the spark out under boost or when the nitrous is applied. Most people simply reduce the gap on the spark plug when boost is a factor in the equation. This means the distance the spark has to jump is reduced and the resistance has dropped. On the 4.6L engine with 6-10 psi of boost, you can get away with a gap between 0.035-0.040". More than 10 psi of boost is pushing the limits of the stock ignition and you really need to upgrade to a more powerful voltage supply. MSD makes an MSD DIS-4 system to do just this. The lower the gap setting, the less power you will make though. Ideally, with a blower, you want to run as close to the stock gap as possible. This cannot always be done and with the stock 4.6L ignitions it's down right impossible. There is another solution though.
Denso makes an iridium type sparkplug with a tiny "u" groove channel in the ground electrode. Some of you smarter types may have noticed the similarities between the Lightning FM1 plug and the Denso iridium plugs. The iridium makes the tip of the electrode very hard. The manufacturers are able to reduce the overall diameter of the center electrode, making the tip, very thin and to a point. This dramatically reduces the voltage required to jump the gap. As we all know, electricity flows to the path of least resistance. So with a larger gap and a supercharged engine, you picked up power. The power did not come from the spark plug itself, but rather from the larger gap area that provided a larger flame kernel. The material and electrode size allowed the plug to be gapped at the stock specifications under extreme cylinder pressure situations.
A wise man has told us over and over again, use the Lightning plugs on any supercharged 4.6L or 5.4L engine. Now you understand why. Not only are they able to transfer heat faster than a stock spark plug, the newer FM1 plugs can reduce the resistance and reduce the chances of misfires on a supercharged or nitrous application.
CONCLUSION
Once again. Stock 4.6L spark plugs:
AWSF-32C
AWSF-32PP
One heat range colder than stock:
AWSF-22C (medium wire electrode, copper)
Two heat ranges colder than stock:
AWSFA-12C (medium wire electrode, copper) Application withheld.
Platinum choices two heat ranges colder than stock:
THESE ARE LIGHTNING EQUIPPED SPARK PLUGS
'99-'00 used AGSF-12EE (medium wire electrode) half thread
'01-present use AGSF-12FM1 (fine wire electrode) full thread
Yes they will work in any 4.6L and 5.4L engine as well as the older 3.8L Supercoupe engines. Also, these plugs are not to be used as a band aid for running lower than required octane rated gasoline's in your engines. That's working against yourself. Go as low as you can with the octane rating before it pings then move up a step (RON number). You will make the most power there. Running 100 octane gasoline in your stock '96 Crown Victoria is a waste of money. If you are running a chip or other means to advance the spark timing, then you may need to run 93 or higher octane. Combine that with the colder plugs and a lower temperature thermostat, you have dramatically reduced the engine from being knock constrained.
Furthermore, the colder plugs DO NOT offer a power increase by themselves nor do increase/decrease the voltage requirement, durability or performance, they can help you make more power. A wise old man once told me about a plug that was two heat ranges colder than stock in the AWSF family. I found the part number and posted it a few years ago. So here we are full circle, from the tip of the wise man you can enjoy more power without harmful detonation.
So the bottom line is, use one heat range colder than stock if you abuse the car or see WOT often. If you have a chip that adds timing, drop two heat ranges. This is up to you, but we all agree it's a better solution to use two heat ranges colder than stock. If you are supercharged or run nitrous oxide, this is a no-brainer, go with Lightning plugs or AWSFA-12C.
I hope this helps and enjoy"
im running AGSF-22-FM in mine with stock (40k mile) wires.
seems to run good...
I have NEVER been able to feel a increase in power just by switching to performance wires, unless the previous wires were damaged or bad.
You will not feel an increase in power on a stock engine by simply swaping out good oem wires for msd or ford racing wires. That is just a simple fact.
I prefer to use the recomended platinum plugs since they don't need to be changed every year or so. They are good for 100,000 miles.
Each to thier own though. just my oppinion.
How long / how many miles are the copper autolite 764s good for roughly? Put mine in nearly a year ago, but only have 4K on them.
just so you know 97 marks have no plug wires
and I have heard that the stock cops can handle more than 600hp also I have seen this on a mark that had stock cops and 600hp at the wheels
well with the 103's gapped at .054... I would recommend one step colder if your running stock tune. However, as Gene stresses with his tune/chip... to run 764's.
Mind you plugs cost PEANUTS.... If you buy 764's 103's and 93s... for like 30 bucks for all three sets. Also, the lightning calls for 103's in my parts store's computer, which is 1 step colder.
I was losing power with the 103's gapped at .054 with my tune... I couldn't tell you why. But I was told by my tuner to run 764's gapped at .048.
I didnt even bother with the 93's... but if I wanted to buy them they are like 1 and change from my parts guy but hed after order them.
For the record:
AWSF-32C = 764 autolites (but autolites are copper better conducter)
AWSF-22C (not made anymore) = 103 autolites
AWSF-12C (Also not made anymore) or AGSF-12M-C1 (stock lightning plug still made 9 dollars a piece from the dealer {ROFL} = 93 autolites - two steps colder than stock.
now national parts store list 103 autolites as stock spark plug replacements for the lightning so i dont know really what to tell you there. But what I can tell you is that if you want a "performance" autolite,
AR103, AR93, or AR764, they are a bit more money.
Again i cant stress enough that running hotter or colder plugs depends on what setup you have. As for lightning plugs tricking the mark 8 knock sensor, i'm on the fence on that one.
My car ran well with the 103's stock gap wit no tune, I would recommend. My car runs the BEST with the recommended 764's with the tune that I have. cheers.
ill try to copy down the motorcraft spark plug decoder next week.
im pretty sure all those plugs (32c, 22c, 12c) are all coppers so the autolites are in no way better. i highly doubt the agsf-12m-c1 is a stock lightning plug (unless its the old 5.8 lightning). ill also look this up.
For the record:
So now you're the plug expert? :p
Hint: the C stands for "Copper". I'm not sure where you get your 'not made anymore' information. :rolleyes:
I have used Autolite 764s. They are a good economical replacement plug for stock applications. The AR series from Autolites are not to be confused with the 764s just because they are Autolites. Simply put, they cost more and do not work as well.
I have bought AWSF-32Cs and AWSF-22Cs direct from my FLM dealer. The last set of plugs I bought was AWSFA-12Cs, granted they were harder to find but they were still available.
i got the not made info from a from a ford parts guy at the dealer who called motorcraft for me, and then called me back personally to tell me that. THEY ARE NOT MADE ANYMORE THE ONLY PLUG THAT THEY MAKE IN THAT FAMILY THAT WOULD WORK IS THE AGSF FAMILY. AWSF line is discontinued, I tried to buy them through the ford dealer etc. If im lying call your ford dealer and try to get them. If they have them, its because they have them in inventory... they cannot get them from Motorcraft anymore.
because they probably have a stock pile in there warehouse. im sure if you make a stink about it they are still available to buy from places. I'm just trying to say that AWSF plug is not manufactured anymore as AWSF, and if you are able to purchase it from the dealer, its not because they ordered it from "motorcraft" its because they have them sitting in stock, since they are not for a specific late make and model etc.
again awsf-12C's your running are relatively the same as AGSF-12FM1 or whatever the stock '01 and up Lighnting plugs are.
Like I said, be prepared at the dealer if you want those plugs, they are like 9 bucks a piece.
i "got not made anymore" right from the people who make the product, Motorcraft.
My point is that there is no guessing with the Autolites, they are great for the price and you can get the same heat ranges as the magical motorcrafts at a fraction of the cost. You can also buy them from your local parts guy over the counter.
Driller, do me a favor - Stop by a ford dealer near you and eyeball the AGSF-12FM1 '01 lightning plug finewire, im sure they look exactly the same as the awsfa 12c plug. Better yet, have your FLM parts guy call Motorcraft direct and try to order those plugs since you don't believe me? :shifty: :p :rolleyes: :rolleyes: ;) :mad: :( :) :p :D :rolleyes:
No finewire here...
they dont. i have many FM plugs in my garage and would have no problem taking a pic of 1 if you like.
well if youd like - im just confirming what the local ford dealer parts guy, who called motorcraft directly for me told me.
What are the differences running the AGSF series for AWSF series?
vr your running agsf series right? And you work for Ford!
thread length would be different on the newer plugs because of the suit. thats why your older plugs only have four threads on them. The threads in the newer lightning heads for the plugs are doubled because i guess the older lightning heads like the early modular heads only have 4 or so threads in the heads that were succeptable to damage right?
I guess I better stock up. :D
If someone would do a comparison between the agsf12m ones and the awsf12c ones would be awesome. I am just going to assume that they are the same spark plug (for the lightning) as this article above discusses. Any other differences, please speak up! The awsf are relatively affordable so i hear but i can tell you the agsf are not.
However, Autolite lists 103's for the supercharged ford lightnings, which is 1 step colder than stock on a mark 8. Whereas the motorcraft ones we are discussing are two step colder than stock on a mark8 but stock for the lightning... confuses me a bit.:(
