lexdiamondz10304
Knuckles: $120
Labor: $40
TOTAL: $160
Dealer parts: $610
Dealer Labor:$450???
TOTAL: $1000+
I just tossed these on my car on monday. What a great deal. $120 is way better then the $520 the dealer wanted for them. Two Thumbs up. Just a couple weeks ago I put new wheels and tires on the car.
Do I need an alignment after putting the lower ball joints on?
I don't want to chew up the brand new tires.
On a side note. My stock michelins went 77k miles. I think that is a record for the mileage I have driven a single set of tires.
Good deal though. I just crawled under my '02 with 95k miles over the weekend to inspect. My originals are still solid as a rock, with no torn boots. So far. And just like last year, whatever clunking/knocking I get from my front suspension during the first few driving miles in cold weather, has now disappeared altogether with the warmer temps.
Crab Daddy, when you installed the Euromarque ball joints did you use a press or the oven/freezer method LS Monk mentioned?
Good job.. Is that a problem part for th V8s only? Or do the V6ers go through that as well.
[*]Remove the hub. (You have to undo your fender liner to get to the plug for the speed sensor)
[/IMG]
Great write up. I got some good printed information from Eric at Euromarque. I may have misunderstood the above writeup, however I unplugged the speed sensors at the hub, slide off the keeper clip and the plug slides right out.
s.
I'll add, "use new Nylok nuts for everything you disturb, or at least, use Loctite hard thread lock compound." My local NAPA store has all of the Nylok fasteners for a fraction of the Ford parts cost, never mind the time you wait for the order to arrive. If you have the time, you could order through five star ford. My local dealers do not stock these things.
