Upper Control Arms MKVIII=T-Bird?
Hemihed426
Inman
I saw this asked on another forum and nobody had answered,wondering if any body knows the answer to this question. The Mark VIII control arm looks identical to the MN12 T-Birds except for the ball stud mount for the ride height sensor. If you have a coil conversion you obviously don't need the stud and there is about $30 difference in price. Does anybody know if the other dimensions and geometry are correct to be able to run the T-Bird arms on a MKVIII?
Ride height sensor spot on mark viii is the only difference, they will bolt up directly and yes with a coil over mark arms are not neccesary, even tho most argue mark viiis are mn12s:D
I was at Rich's house the other night, (Mespock) and he mentioned that! I think it is going to work fine, but maybe PM him, as I know he will know-
mark is an FN10 though many parts are shared with the MN12
The Mark VIII's are $83.14 at Advance. Thats an expensive little ball on there.
gen 1s are mn12s and gen 2s are concidered fn10s, odd but true doesnt make sense but thru alot of research and head scratchin its what i came up with
why would that be, the gen 1 and gen 2 under the sheet metal are the same exact chassis from 93-98 the only thing that makes it a gen 1 and gen two are some body cnages, not chassis changes all marks are mn12's
Where did you get that info? Everywhere i have read says all Mark VIIIs were on FN-10. The Thunderbird is on the MN-12 and its not the same platform as a Mark, it is smaller.
The whole gen change didnt make sense as far as chassis (cause there wasnt) but i always concidered them all to be mn12s and still do but maybe because of all the mixed opinions thats what they came up with, and i also do recall a magazine (dont remember which) refered to the mark as an mn12, thats what i beleive regardless but everyone beleives differently
has anyone accually done it with airbags...where did u mount the leveler...i dont need the leveler i could cut it off and use it for a paper weight...30 bucks is 30 bucks...NAPA Retail on the 96 tbird is $156(lifetime warrent.) $181 for the mark8...and theres about a $10 diff from left to right lol...
