Need help identifying disconnected lines
efaccio
lancaster
Hello all,
Just purchased an 03 Lincoln LS V8 and was recently replacing some of the plastic cooling parts as it was leaking and overheating, when I ran across these two lines being held on by electrical tape to the intake. I have ordered a TPS in response to the engine's fail-safe mode coming on after about 30 minutes of driving, but could it have been due to these lines? I don't know what they are and would like to replace them. Forgive me if it is obvious, but I'm not the most mechanically inclined.
Thanks
I hope the attached .pdf file helps. Copied from the Lincoln LS service manual. You need to add "3W4Z-" in front of the part numbers to do a search. https://car-part.com is a good source to start looking. I bought the turn signal/wipers column switch from Mills Auto Parts in Ft Wayne, Indiana. They have a yard with Ls's and may have the tubes you need.
Good suggestion to get a shop manual first thing.
Plenty on EBay in digital form. It will save you money!
Thank you, The diagram did help. One of the hoses is discontinued, so I definitely will be checking out mills auto parts.
