3000 rpm
ls2002ls
yonkers
HI guys, so i have a 2002 ls v8 bought new in dec 2001. I have 39,000 miles on it. Today driving home on the highway doing 70 to 75 miles an hour half mile from home breaking for a red light i had to press hard on the brake to stop and thats when i notice my car was revving above 2000 rpms in gear out of gear it would stay at 3000. got home and parked the car in my driveway with engine running had some antifreeze on the ground. looks like its coming from the thermostat cap. its wet around that area. all hoses are dry and degass bottle is dry. its only down a little. i replaced all hoses degass bottle put in aluminum tower a few years ago. there is anti freeze on some electrical wiring plugs on the driver side front. turn car off restarted still 3000 rpms.. no warning lights on dash wont be able to check and codes till tomorrow. Any ideas. Thanks Nick love my ls
so no codes ordered idle air control valve from rock auto coming in a few days. found the anti freeze problem,, bad clamp. fixed it.
Yea the IAC Valve is the first thing i would suspect when having a idling problem and no codes. Any air hissing sounds? I would also check my vaccum system for any dryrotted or broken hoses. Post back an let us know what you figure out.
I'd check that the throttle linkage or throttle cable is not sticking anywhere.
You can do that in the engine bay OR by feeling the response of the accelerator pedal.
Thanks for the reply Firebrian. linkage is good. changed out the iacv. rpms does not stay a 3000. on cold start it goes to 1800 and slowly drops down to 900 but when i press the gas pedal it stumbles. have a new tps coming in a few days. also going to clean the mass air flow sensor. car has only 39000 miles on it. great shape inside and out. this is the first time i have this problem.
Hey Buckie. i put in a new iac got a tps on the way no air hissing sounds. its not stuck at 3000 rpms like before also got a torx screw driver on the way in so i can clean the mass flow sensor. justs doesn't idle right.
What brand IAC valve did you buy? I have to say nothing beats Motorcraft. I know motorcraft is expensive but its expensive for a reason its always the best choice when it comes to the Lincoln LS. There was a post on here not too long ago a guy replaced his IAC with a aftermarket one and his LS still wouldn't run right. He went and bought a Motorcraft IAC valve an it fixed his problem. I know thats not the answer you wanted to hear. It was hard for me to believe a new aftermarket IAC gave the LS problems but before you throw alot of uneccesary money at you're car do you still have you're old IAC? You can always try cleaning it up and then spray a little lubricant on it and take a screwdriver and press it up and down to make sure its opening and closing then stick it back on to see if it straightens the idle out. It might just be gunked up and sticking open. Since the idle has come down with the new IAC thats what i would try before i just started replacing parts. Let me know how it goes.
couldn't find a oem got a wells. car is no longer stuck at at 3000 rpms. starts fine revs around 1600 and drops to 900. when i give it gas it stumbles. got a oem tps coming in on wednesday. no codes or check engine light.
pic's of my ls
Ok its normal for the LS rpms to be a little high when first starting but should go back down after about 10-15 seconds. How does it run when driving around? Regarding that stumble did you unhook the battery before you worked on it? If so sometimes the car will run rough at first but the more you drive it the computer should start relearning its normal fuel/air trims if everythings back to working at factory specs. Thats a sharp looking LS man congrats!
so today new motorcraft tps came in. installed it and cleaned mass air flow sensor the other day i put in a new iacv. disconnected the battery for 15 minutes and also turned on and off the headlights. hooked the battery back up started the car and it was smooth as ice. i let it idle for 10 minutes took it for a spin put the ac on everything ok. runs great. Thanks Buckie for hanging in.
You're welcome! Im glad you got it fixed
