FDR
I think you'd need to see what exactly isn't working. The hydraulic fan isn't all that loud. I don't really expect to hear it while driving. If the tech didn't listen for the fan until they shut the engine, they wouldn't hear the fan because the engine is off
If the fan does spin when the engine is running but never speeds up, that's the actuator
If the fan does not spin with the running engine, then it's the motor, pump, or fluid
I would be curious if the fan reservoir was topped off with coolant. Fan symbol=cooling system is a fairly common mixup
