Boiling in Degas Reservoir but coolant is 210 F.
Lincoln LS
  1. AmsterDutch
    AmsterDutch Dedicated LVC Member
    1,636
    263
    Jul 9, 2017
    Midwest
    I'm going to be doing a coolant system rebuild ...I seen my degas reservoir boiling today when I opened the hood to check my coolant level...funny thing is Forscan is reading my Engine coolant at 95 C. -210 F. ...when I put the heater/defrost on my coolant starts to boil ...when I turn it off the coolant stops boiling...when the coolant is boiling the temp reads 95 Celsius ...when coolant isn't boiling it reas 95 Celsius ....strange system in this 2002 LSE 3.9 ...whatever the case may be looks like I'm going for a rebuild ...I've done it a few times ...FWIW ...the degas cap barley hisses when I take it off hot...has to be air getting in the system
  2. milehighmikey
    milehighmikey Dedicated LVC Member
    745
    33
    Apr 2, 2007
    Nashua
    Is the cap holding pressure at all? Squeeze the upper radiator hose on the engine when it is boiling. Is it hard or is it too soft? It could be the cap. You have to pressurize the system to raise the boiling point, and that could be all there is to the problem. I just had the same thing happen to my lady's Subaru WRX. The hose was not getting even close to firm, and it was boiling at normal temps. A new cap solved it.
    • Like Like x 1
    • AmsterDutch
      1,636
      263
      Jul 9, 2017
      Midwest
      Funny you say that ....the previous owner has a aftermarket cap on the degas reservoir...I was thinking that might be a good idea to try a new cap ...being it's a 2002 once it started to boil my first instinct was to change out all plastic I may as well just order a whole new degas reservoir and give it a shot before I dive into a full rebuild ...it wouldn't hurt giving it some more flushes anyway due to th he previous owner using Dex-Cool
    • milehighmikey
      745
      33
      Apr 2, 2007
      Nashua
      The cap by itself is a pretty easy find, mine for my LS came from Advance Auto Parts 4 years ago, still working well!
      • Like Like x 1
      • AmsterDutch
        1,636
        263
        Jul 9, 2017
        Midwest
        The hose seems kinda soft I think...not really sure though ...not an expert in cooling systems by any means...just know boiling coolant = problems in the system = change the plastic coolant parts...How hard or soft should the upper radiator hose be?
      • AmsterDutch
        1,636
        263
        Jul 9, 2017
        Midwest
        The simple answer to this question is that the boiling point of water is 100 C or 212 F
        of course the the boiling point of water depends on the atmospheric pressure, which changes according to elevation. The point I'm trying to get at is I flushed the entire system twice with distilled water until water was the only thing coming out ....could it be that the water to coolant ratio is greater than it really should be ...because even today the highest temperature I was reading on Forscan was 96 celsius?
      • 04_Sport_LS
        04_Sport_LS Dedicated LVC Member
        3,145
        347
        Jun 12, 2012
        Somewhere around Lake Erie
        You could try pressurizing the cooling system while cold... and see if it holds pressure. If it drops quickly... you probably have a leak that you might be able to hear and locate.
        All you need is a cooling system pressure tester.
        • Like Like x 1
        • AmsterDutch
          1,636
          263
          Jul 9, 2017
          Midwest
          UPDATE: I changed out the Degas Reservoir Cap today ...The car's temperature is a steady 95 celsius and the coolant once again only starts to boil upon turning on the climate control... this is so weird ...coolant system rebuild here I come
        • 04_Sport_LS
          3,145
          347
          Jun 12, 2012
          There is a difference between boiling... and bubbling. If it is happening only when you turn on the heat... your DCCV might be cracked be and/or sucking air. Possibly the "quick connect" hoses to/from the DCCV... that attach to the aluminum tubes that run along the passenger shock tower. There are O-rings in there. Worst case... the heater core.
          Pressure test the cooling system cold... and see if it holds. If not... get some U/V dye... and a black light... and check it while hot. There's gotta be a leak somewhere.
        • joegr
          joegr Dedicated LVC Member
          19,866
          1,491
          Dec 10, 2005
          Gulfport
        • AmsterDutch
          1,636
          263
          Jul 9, 2017
          Midwest
          Okay 04' Sport ... I will pressure test the system cold ...going to purchase the OEMTOOLS 24444 5 Adapter ...I need something like this and the price looks fair
        • AmsterDutch
          1,636
          263
          Jul 9, 2017
          Midwest
          I think you're onto something here the Dual Climate Control isn't working.... when I try to set a different temp on passenger side...the digital numbers only decrease and increase at the same time with the driver side arrow...of course If I the pressure test shows I have a leak I planned on changing it out anyway of course ...thinking I should do the radiator and water pump also since I'm in there
        • joegr
          19,866
          1,491
          Dec 10, 2005
          Gulfport
          That would be an internal fault of the DATC (never seen that one, though), and not anything related to any faults of the DCCV.
        • AmsterDutch
          1,636
          263
          Jul 9, 2017
          Midwest
          Wasn't sure if that was an internal fault or the valve itself ...I was leaning towards an electronic fault in the DATC panel but my wishful thinking brought me to hoping it was something in the valve itself...could it be a blown fuse of any kind?
        • 04_Sport_LS
          3,145
          347
          Jun 12, 2012
          Well... at least you have some pervious experience replacing the DCCV... if necessary. :rolleyes: :D
          • Agree Agree x 1
          • 04_Sport_LS
            3,145
            347
            Jun 12, 2012
            In theory it could work... but not sure how a leak would be found.
            Unless you mean for just working the air out of the system???
          • 04_Sport_LS
            3,145
            347
            Jun 12, 2012
            Words to live by when it comes to auto repair. :cool:
            • Like Like x 1
            • joegr
              19,866
              1,491
              Dec 10, 2005
              Gulfport
              You would identify that there is indeed a leak by watching the vacuum drop after you turn it off. You may be able to locate the leak by sound using a mechanic's stethoscope.
            • 04_Sport_LS
              3,145
              347
              Jun 12, 2012
            • 04_Sport_LS
              3,145
              347
              Jun 12, 2012
              Then again... would the larger or softer hoses collapse under vacuum... even with a tiny leak?
            • heyjewel
              heyjewel Well-Known LVC Member
              466
              36
              Oct 5, 2015
              auburn
              Dutch - going to recommend you consider what fixed very similar problem for me, after replacing several other things - that expensive little hydraulic fan actuator.
              • Like Like x 1
              • AmsterDutch
                1,636
                263
                Jul 9, 2017
                Midwest
                Yeah the hydraulic fan isn't spinning very fast that's for sure ...I siphoned the Mercon out of the reservoir and it was really milky to say the least...still going with the rebuild though ...all the rubber hoses look like hell and why not put the S-Type T-stat housing on ...I'm thinking about experimenting with that aluminum degas reservoir ebay also ... ty his LSE will need some suspensionparts sooner than later ....O Boy here I go again rescuing an old LS from the grave ha ha ha ..by the way the DATC panel started working now both passenger and driver side Dual climate control digital temperatures work when pressing buttons up and down...my forscan isnt connecting up with the car anymore though ...works fine with the 06' but the LSE doesn't want to connect ...scratching my head on this ...PCM? It sucks because I want to run live data but I'm unable to connect with it...
              • heyjewel
                466
                36
                Oct 5, 2015
                auburn
                Well that little actuator controls fan speed but of course it is controlled by something else.
                Milky hydraulic fluid? Hmmmm no idea on that unless maybe water got in and the fluid is boiling too? I dunno on that one.
                • Like Like x 1
                • joegr
                  19,866
                  1,491
                  Dec 10, 2005
                  Gulfport
                  The PCM drives the fan actuator.
                  I can't remember... Does Forscan ask if it is CAN or not. Your 2nd gen is CAN, but your 1st gen is not.
                  • Like Like x 1
                  • 04_Sport_LS
                    3,145
                    347
                    Jun 12, 2012
                    Yeah... that's usually a sign of water. In the case of Dutch's new adoption... it could be condensation from sitting around for a while before he bought it.
                    • Agree Agree x 1
                    Share This Page
