Itzyaboy Jo
Took my car to a supposed emissions specialist shop for a reoccurring P0411 code ( 2ndary AIR incorrect upstream flow detected); P1633 Battery High Voltage (although code itself reflects low voltage when Google searched
) and P1504 Idle Air Valve.
Upon initial fix P0411 and P1633 no longer appear, but P1504 is still present, along with P1507 another Idle Air circuit code and P1565 speed control system.
As the mechanic pulled up with my vehicle he "claims" my transmission flashed E on the dash and now my car will NOT drive in D5 or D4, but it will in SST 2 & 3; however, when you upshift from 3 to 4, 4 flashes but it drops back down to 3 immediately. When in auto E is NOT on the dash, it shows the gears D5 & D4 but car will NOT move, although it does in Reverse.
The car had 189,601 when I dropped it off, but it now has 189,971, which means my car was driven 370 miles since it had been dropped off I'm aware there trans is supposed to be checked at around 180,000 - 190,000 miles according to manufacturing specs, so the problem may have been imminent, however, the excessive and unexplained mileage put on it by the "technician" definitely ushered it in.
Currently there is no transmission code associated with the problem, so I'm wondering if anyone KNOWS what the problem may be. I've heard trans may have went into limp mode to save it from being a total loss, but with no code I don't know what the problem may be. I've heard solenoid pack and some sort of gear spring
