Hey guys I’m having a sudden problem today for no reason all my electronics or not working. No ignition chime, dome lights, fuel pump prime, door locks, windows, nothing works. I have 13.2 volts at the battery so I know its not a battery issue. I’m getting power to only half of the fuse box located in the trunk. All fuses on the outer side have no power. Any ideas on a central fuse that could be blown or maybe a relay? All those fuses control everything that’s not powering up but the fuse box itself seems to not be getting power just to that side, all fuse on the inside line are powered up and fine. Thanks fo any input.
