g1ft, I just noted by your listing, in this case the left sway bar end link is more expensive compared to the right side. Kinda contradicts my other thread statement about right side parts being more expensive. This is in some instances, the right side control arms are more then the lefts. Is what it is.
The OEM end links are skinnier then the Moog's. The Moog's seem more robust and solid. Many of us have used them without issue. Moog is a very reputable brand name in the suspension game. They only provide the greasable units, which means they come with the grease nipple that you'd need to turn in. They easily strip if you crank them in to much so easy on that.
Your OEM Ford toe adjust linkages are a direct replacement. You could have gone for some cheaper Rimmerbro JAG replacements from the UK but you'd have lost the rear passive steering in those. Not a huge deal as the rear end would feel slightly tighter and not follow as much in turns. Some insist on using the OEM passive steering, others don't even notice a difference and my self I say not enough race car.
I have OEM on my wife's 03, DEEZA non passive on my 01 and UK Rimmerbro JAG's on my 04 LSE only because the DEEZA's are no longer in production for the LS.
Your list looks good, you can do this your self, just need a jack, stands, an impact, couple of wrenches and some PB Blaster or WD40 or something simular. Spray the hardware the night before. The new hardware as in the nuts, are provided with your order.
Torq them to spec which you can find in our online work shop manual. Retorq a week later is always a good idea.
Be sure to keep your MOOG end links in their respective boxes until install, you can see the part numbers differ right from left because they in fact are different with respect to the angles, keep an eye on it.
If you need anything, let us know.
Have a read at the rear suspension section in the online work shop manual.
