No Results Yet
My car is having a similar issue. I am going to check the transmission fluid tomorrow. Did you ever find the problem? If you/ your husband was able to fix it please post how, it could be helpful to me.
Hello Berny
No...unfortunately, after working on our LS for three months, as time allowed, and replacing the "timing belt", other small parts associated with that, and "PCV valve" (as an experienced Ford and NASCAR mechanic who ran a diagnostic suggested)...after my husband got the engine back together, the Lincoln stalled out again just like it had been doing before. He waited 30 seconds, it ran, then died, and after the third try, it would not even start up.
He has not checked the transmission fluid yet, but will do that and do an extensive check for vacuum leaks after he overhauls my Toyota...as I have had no working vehicle for almost four months now. We're going to cover it up again and let it sit until he can get back to it...whenever that might be.
Needless to say, it has been extremely frustrating as he has replaced the EGR valve (that was throwing a code), IMTV sensor???, some other thing, cleaned the MAF with appropriate cleaner, new timing belt and associated parts, and the PCV valve (which was also coding) and hoses (I think).
If we find the solution, I will certainly post the results, but that will not be for quite some time, as my husband cannot extend anymore effort towards the Lincoln until he gets the Toyota running. In the meantime, if anyone has any other advice that has not already been posted, we would GREATLY appreciate it!
