Hi Guys,
When I first looked I thought these were fine. What do you guys think?
With everything apart (have removed the LCA) and it would just be the outer bolt (by frame) on the Strut Rod to change the frame bushings.
Being in this far I would just change them, but have heard aftermarket bushings do not last.
I have to change the LCA Strut Rod bushings and wasn't able to find all Ford, so do I put Ford bushings in for the Frame area and after market for LCA or go all aftermarket or leave as they are?
I think you need sleeves for the Ford Frame bushings or is that just for the LCA SR bushings?
I ask as I have seen many posts here that said you are better off sticking with the original Ford bushings than replacing with after market.
