lincoln_zero
2005 LS V8. Needs the worx. I was told to stay away from Bosch for the LS's. What is everyones favorite Brand/Grade of plug and why?
That's about .039". I believe my '03 sticker says 1.1mm(.0433") It couldn't hurt to close them up just a little more. My car currently has Denso's in it, and they were gapped about .054" out of the box. That's way to big for the weak insulation that the boots provide. I gapped them at about .034" hoping that the lower firing voltages will preserve the coils/boots a little longer.OEM is NGK.
It's important to verify that the gap on each one is truly 1.0mm.
My experience is that the gap gets larger as the plug ages (electrode erodes), so I set them to the minimum specified so that they aren't past the maximum before it it time to replace them.
Smaller gap = lower voltage, but higher current. Correct gap (in spec range) = best transfer of power to the ignition.
As much as I would love to care for my LS like that, I sadly don't have the time =( Platinum sounds good tho, however I can't find any NGK platinum for the LS. I really don't want to be replacing plugs every year. any other suggestions?As with everything in life it depends. I preffer NGK but the sticker under my hood lists Denso. I have been using NGK V-Power plugs. I replace them at least once a year but I do drive over 25k mi a year and tow almost 30% of the time. "Platinum" plugs are usually recommended for long term use as they supposedly don't deteriorate as fast as regular plugs.
Good luck.
... Platinum sounds good tho, however I can't find any NGK platinum for the LS. ...
O E M
it is what the engine was designed to use. who am I to tell those engineers I know better...
Really?
NGK BKR5EGP
http://www.amazon.com/NGK-BKR5EGP-G-Power-Spark-Plug/dp/B000COTPIM
Also at most of the auto stores.
EDIT: I checked on ebay, all the listings say those are not comparable with the LS joegr. I can't find NGK platinum for the LS..
...EDIT: I checked on ebay, all the listings say those are not comparable with the LS joegr. I can't find NGK platinum for the LS..
So.. Much.. OEM.. Failure...
well with pretty much zero aftermarket support, 98% of the time your options are a fairly high quality OEM part, or a super cheap chinese knock off part that you're lucky if it last a year.
OEM coils > ebay coils
OEM degas bottle > dorman bottle
OEM shocks > every other aftermarket strut except stance coilovers
OEM bushings, end links, tie rods, rear toe links > all aftermarket brands other than the couple of Moog parts available
OEM cooling parts > non existent aftermarket parts
Funny, multiple sites say they fit 2000-2006 V8. I have them in my 04 and my 06, if I remember correctly.
Ebay says they don't fit because they are selling them in sets of 6.
Look it up at O'Reilly Auto Parts
NGK also says it fits: http://www.ngk.com/product.aspx?zpid=9309
My $80 set of Chinese Ignition Coils are 1.5 years in, seems fine to me. Meh.
The way I see it, most of this stuff is so cheap to buy compared to OEM that even if they fail twice, I still spent less than half. And since OEM is not a guarantee, both are a Risk. And since "Aftermarket" is not a brand, its just a term, you can potentially get the best thing ever that never fails, or worst that failed as soon as you put it in. OEM is OEM, it WILL fail, just you have a good idea when lol
...joegr, do you find the G power last long?
Yep, always replace the sparkplug anytime a coil is replaced.They're supposed to be good for 100K miles. I expect them to last about as long as the coils do.
But when you say OEM bushings, what do you recommend for GenII front sway bar bushings? ...
... I was going to go the energy route unless you advise otherwise.
its not that they have been adhesively adhered, instead of a "C" holding the bushing and the bar to the car, the bushing bracket wrapps all the way around the bar so that it cant simply be removed, I had to cut mine off with a dremel and a bunch of cut off wheels (wasn't room for a bigger, stronger tool) so since they dont come apart, the only way to get OEM ones is to buy the whole assemblyTo my knowledge, mine were adhesively adhered from the factory
