2002_lincolnLS
Custom User Title
I fill the filter as much as I can before installation. Gotta be quick spinning it so it doesn't drip. It helps prevent a dry start before the oil pressure builds. I don't recall seing the oil light stay on the short time after the change since I started doing this. I think I say it on the Goss' Garage segment of Motorweek. Then again it may have been the old Shadetree Mechanic show......
Putting oil on the gasket should keep it from sticking to the mounting surface.
When I was working at a local ford dealer we did this with all diesels as their filters are huge and take for ever to prime if you don't prefill. I also always put oil on the gasket. If a car has a larger filter I would prefill it, but usually not.
