MONTE 02 LS
Hi all, I've been searching around on the site and am a little confused, I have an 02 LS non-sport and have seen 27mm and 28mm. Was woundering which one is the best fit, ES has them both listed. Thanks for the help
^ Well put Frankly I must say. I can tell you've been taking notes.
Right you are, with any car you have to keep the maintenance up, things need checking, can't just keep putting fuel & oil in it while ignoring the rest.
In my younger years, I had a POS Cutlas, coming around a bend, SNAP ... pulled over, passenger side front wheel pointing inwards, how fun that tow to a garage was!
This may be an old subject...but
Does anyone know if there are stock ride height replacement coil springs available aside from Ford parts?
For those that have done it on the gen II how difficult was it to cut them off? I'm just concerned about space. I remember on my Gen I there wasn't much room. What did you use? Cut off wheel? Dremmel? Sawzall?
Pain in the ass...
there is no room at all, couldn't get a small cut off wheel on either my straight or 90* die grinders. had to use a dremel with the little miniature cut off wheels, not too hard to reach but the steel is thick. took forever to cut, wheels kept breaking, think I uses a pack(ten wheels to a pack) and a half and about an hour to a hour and a half to cut them both off.
