lincoln_zero
Resolving my 2005 LS A/C Problem, please advise.
Hi everyone,
So Here's whats happen/happened in a nutshell. Bought this 2005 LS from a small used car dealer October 2012, dealer said she got it from an Auction. By summer 2013, realized that there is no A/C, but didn't have the time to work on it so didn't tackle the issue. Now as of this year, I took the car to my family mechanic who ran the dye through the lines, after a full week at the Shop they assumed its the Evaporator located in the dashboard.
Today I had time to play with the car. Its 20 degrees Celsius outside, so hard to determine if just outside air is cold or A/C coming in. I turned the A/C on, and its cold, but not much colder than outside. Upon heavy acceleration I noticed that the air got cooler, and when I stopped, it slightly warmed up. So I pulled into Walmart's parking lot, Parked the LS, and began to Rev to 2800 RPM... BAM!! freezing Cold air, much much colder than outside, coming in. Very cool. Not quite 100% there yet, but yes THAT was A/C coming in.
I Let off the throttle, and the air slowly Gradually warms back up to just slightly colder than outside. So I engage the car, select shift into second gear and drove the speed limit at 3500 RPM, BAM freezing air again.
That's the symptom. Any thoughts? Thanks fella's.
Hi everyone,
