PaulPool89
(EDITED more pics) Hey Guys!
I'm back driving my dad's 1998 Lincoln mark VIII LSC Collectors Edition!
Had a 2002 Nissan sentra 5speed that I got into a bumper tap. Well for the SUV is was, not even a scratch. I bent my radiator core support and jammed my hood shut. Not worth fixing it b/c I don't know welding.
Anyway's the heat stopped working. it still blows, but only cold even when set to 90. I will edit in the codes I got from ATC test when I run it after work. (I only just found out that diagnosis system even exist doing a forum search just now)
http://www.lincolnsofdistinction.org/lincolntech/modrepair/blenddoorrepair.html
Does all those components really have to come off? I read somewhere a guy said he didn't have to drop the steering wheel.
http://www.markviii.org/LOD2/blend_door_reinforce.htm
Also that the new part can be reinforced as it shows in the guide. But im not really wrapping my head around how that works from the pictures im not understanding. Can anyone explain that better to me?
2nd in the spring there was some flash flooding and I was driving it thru a puddle that came up to touching the lugnuts on my tires, but not enough to get sucked in. This lady without thinking drives right thru the puddle heading in my direction, pushes a wall of water up over my hood, and floods it. Mechanic opened up the plugs, turned engine over. He said a lot of water came shooting out. But he air dried it, put it back together, and car still runs. However now it has a rough idle. Like someone keeps tapping the gas peddle rhythmically. How do I diagnose what is causing it?
Still have trans issue but that's for another time. (anyone selling a new trans for my model?)
Lastly I need to replace both from wheel bearings. I read that the spindle might be damaged too. Where is there a guide or how-to replace the spindles?
My new wife (got married Feb 15th) deff enjoys riding in this more than my sentra. But I am disappointed with the traction control. Fishtails something terrible in the snow we just had.
Anyone here in South Jersey?
Rims front after, rear before
Click For full size
Click for full size
Headlights after I did drivers side, and then both done. Passanger came out nicer. They have moisture inside them.
Click for full size
Click for full size
There is a bit of rust at the bottom of the driver's side.
I felt brilliant thinking of just putting my finger in the shot lol
Front seats are actually in pretty good condition. Drivers seat left side feels like its missing some foam. Waiting on collectors edition mats to get here.
Over 200k and looking pretty good for it.
Back seat condition is perfect.
The walnut on the steering wheel is worn to the wood in a few spots. Not sure how to fix that. But otherwise everything works and looks nice.
#0792
Click For full size
Click for full size
Click for full size
Click for full size
#0792
