Epwillis
Drove the mark today for the first time in a while and had great heat on my way to school and when I left school, so great that not thinking I turned it to cold to cool off and kept driving home. Got home and then had to leave again and let the car warm up and got driving down the road and bumped the temperature up on the climate control and had nothing but ice cold air out the vents.....even at 90 degrees. Now when I did switch it to cold(stupid Decision) there were no noises of something breaking or anything. While I was at school I topped off my coolant(after the car cooled off) because it was about an inch below the cold fill line, so I filled it to the cold fill line. Now when the car runs the coolant level is almost at the black plastic of the coolant reservoir(assuming that's normal), I wouldn't think that if the coolant was over full it would cause no heat but maybe someone knows something that I don't. The car is not overheating and running around the middle of the A to the bottom of the M. My question is from reading the information above does anyone think they can point me in the right direction? I'm leaning towards blend door actuator because when i change the temperature up or down I can not hear the door moving, although could it be a thermostat and still not overheat? Any Help would Be greatly Appreciated.
