manny
hello everyone, I'm having a major problem with this lincoln, my heat worked fine all of a sudden it stops, from what i've read on the forums it seem like the DCCV was gone bad, so I replaced that and also put in a new thermostat. After all of that im still not getting heat, the pipes running in to the heater core is not hot or warm when i touch them, i also disconnected the hoses going to the heater core to see if any water would leak and none is coming from the pipes or out of the heater core. I have no idea what to do or try next,, i also bleed the water lines as recommended as well.. any help or ideas would be greatly appreciated.
