Let's see. Did you let the MC get empty at any time? If so you may have introduced air into the line which means a complete rebleed is needed. Did you ensure the bleed screws are all tight without overtightening and not leaking? And what exactly was your bleed procedure? The only way I've ever gotten brakes to bleed properly was with the 2 person method where one person pumps the pedal and holds, and the other (me) cracks the bleeders open until fresh, clean fluid comes out. And, the order is furthest wheel from the MC to the closest wheel. I know there are other methods but this is the only one that has ever worked every time for me. And now for the most boneheaded question, did you remember to put the brake shoes back in? :Bang:N
If any of this seems that I'm insulting your intelligence, I'm not. I won't say how many of these dimwit mistakes I've made myself in the past.
