So my car has had this rattle from the front passenger side wheel area for quite some time, but it hasn't been an untolerable or worrysome issue until recently. It doesn't sound like a thud or thunking noise like the noise people refer to when I research the issue. Use your imagination a little bit and picture one of those springy door stoppers that are near your floor in your house. If you pull it to one direction and release it, it makes a metallic rattle noise that dissapates or dissapears in a springy like sound.
Well I know that the dealer had put all new control arms and A-arms etc before I had purchased it, and they look brand new as well as the bushings. However I noticed that this black bar thats closer to the engine bay has bushings in it that are completely split all the way around and are very dry looking. I believe this is the sway bar that I am referring to. Here are my questions..
Would these bushings cause symptoms of rattling sounds like I describe? If so, is installing them a procedure I could do myself? (assuming I'm relatively intelligent and/or at par lol). Also I noticed when I take my wheel off, the rotor is really lose and sloppy. That's never been the case on any car I've ever worked on, but then again it appears these rotors might be held tight and together by the lug nuts? Also I'll add that I used excessive force on the wheels and they had no play in them.
One more thing.. my car has developed this slight clicking/ticking noise that is consistant with the speed of the wheels rotation (the faster I go, the faster the clicking). It does not do this all the time, and when it does it's very faint.. not loud.
Anyhow I just would like your advice and suggestions because you guys have been very helpful. I want to tackle this asap because I am currently not driving my car because I don't want to damage it further.
I will be posting a detailed video tomorow after I crawl under the car, to maybe get better advice and give you guys a view. Thanks and God bless
