G-RELL
FULLY DIPPED LS
She did disappear fast!
From what I've been reading, they're popular on F-Series trucks. The only complaint is that it does slow the flow of the oil out of the pan relative to pulling the normal drain plug, but some have said that the ability to drain the oil while it's still hot could offset this. (I'm not sure if anyone has actually tried that, though.)Sorry to bump an old thread - but I'm considering buying one of these for both vehicles after a buddy of mine recommended it.. I do see people mentioning possible clearance issues so I'd figure I clarify once more before purchasing. Anyone have a bad experience with one of these?
If your drain plug is hard to reach or opens over a crossmember, it might be worth it, but neither of those criteria apply to our mills. Unless you're an ape with no sense of touch, it's pretty danged hard to strip out the drain plug on the LS's pan.
The Fumoto design looks to be quite a bit better than the Fram unit; the Fumoto actually has a spigot where you can attach a hose if you choose, but it's not required. I think there's a reason Fram is no longer selling theirs...Had one on a '96 Sable and the '00 LS. I removed it on both as the hose tends to separate from the drain plug. The idea seems OK, but the execution leaves a lot to be desired.
The Fumoto's body is metal; there's just a snap-on plastic elbow that you can add to make it a 90-degree spigot if you choose. That said, I don't have one on any of my vehicles, but none of them have an obstructed/obscured drain plug.I never liked the idea of replacing a metal drain plug with a plastic tube underneath a moving vehicle...
I (we) are all ears if you want to explain your side of what happened. I found it hard to believe any of it, but as Drizzy said, not explaining what happened and disappearing didn't look to good.
