Lincoln motorsport mufflers installed!!!!!!!!!!!
I love it. It think it suites our cars great. Sounds clean, not rough. Just right. Only reason I haven't ordered a set is because I don't like those dual outlets on each exhaust. Well, that & after the respration of my blue on black, I'm completely out of budget. Who knows what the winter might bring my way. Christmas 2012 I'm asking Santa for a set.
But...they look awesome all shined up,
I had just hacked off my mufflers and kept stock tips on my LSC but I want bigger pipe and get rid of the third cat. Put an x-pipe. I'm looking for that cobra sound or as close as possible. Might go catless and run x-pipe resonator.
^ I plan 2.5 mandrel from the cats back with a dynomax ultra flow x dual in dual out in the centre and pipe all the way back to stock 2013 mustang gt tips.(free score from work :D)
Time for some headers on that sucker and let it scream. :cool: I love drone. You anti-drone folks can keep to yourselves. :p I like feeling the engine talk through every bone in my body. :D
I am not sure what this drone stuff is people talk about ? How does one know if they suffer from drone. What if one suffers from drone but doesnt realize it because drone is awesome to suffer from. meh. my stereo is to loud to even know if i have drone. but if i did. im sure id try to make it louder :)
Bring on the drones! lmao... I've had drone in my truck for over 8 years. I have no regrets! I'm going for a different system myself (one muffler in the middle) but only because I don't have the budget for LMS mufflers or any extra mufflers for that matter. I have my ol' muffler sitting in my shed waiting to be installed.
If ground clearance permits, I might go with dumps on the blown8 after I get headers. I'll be the drone master. :D
From some peoples responses I'm wondering if they REALLY know what drone is. Drone is not loud exh and feeling the rpm's as you goose it. Drone is a resonant frequency that comes on at a certain RPM. You can change this frequency by changing muff length and pipe length. Drone is noticed most at cruz RPM. You level out on highway at 2400 RPM and the cars interior lights up like a howl. It can send wave like resonant thru cabin, as in waa waa waa waa pulsing your eardrums. You can now change that frequency to a higher or lower RPM then your cruz 2400 so it comes on earlier or later so it does not hit at 2400.
"Drone in the exhaust is due to the engine driving the exhaust system
at its resonant frequency. You can't get rid of it, any length of pipe has
a natural frequency, but you can change the frequency (RPM) it happens at.
Stock exhaust systems are tuned to put the resonant frequencies outside the normal RPM range the engine is run in. Sometimes they add resonators for this purpose.
To raise the resonant frequency of a system, shorten its
length. To do this, you can try tail pipes that exit by the wheel (like
GN's have), or you can try a muffler with a shorter internal flow path. If
you have a true dual system, you can change the natural frequency of the
system dramatically by adding a balance tube. If you can't shorten the
system, then you can add slightly less than one wavelength of pipe. This
will also raise the resonant frequency of the system. The wavelength in a
single converter system (not true dual) is a little less than three feet at
3000 RPM. Shortening the system by a foot or so will move a resonance at
2000 RPM to about 3000 RPM.
To move a resonance, calculate the wavelength at the RPM that gives
the resonance you want to move. Then calculate the wavelength at the RPM you would rather it be at. The difference is the length of pipe you need to add or delete.
Add to lower the RPM, delete to raise it. If you want to raise it but you can't cut any pipe out, then add one wavelength of pipe minus the amount you calculated. This will have the same affect. If you add or subtract a multiple of a wavelength exactly, you will not change the resonant RPM.
Wavelength = 1100 X 60 X 1/RPM X 1/4 X 1/2
or
Wavelength = 8250 / RPM
Wavelength = standing wavelength
1100 = speed of sound in air in feet per second
60 = convert RPM to Revs per second
RPM = RPM
1/4 = four cylender firings per revolution (make this 1/2 for "true
dual")
1/2 = standing wavelength is half the wavelength of a "normal" wave
I posted on the Youtube vid that it wasn't loud but it definitely lets you know it's a V8.
I like my car dead quiet cause I'm a stereo guy and I want a low noise floor but that seems very doable to me.
Last Drone vehicle I had was a '71 Elcamino with Cherry Bomb Header Mufflers and that was quite mind numbing :mad:
