i really need help for my car
air ride is failing....you have a leak...most inexpensive fix is coil conversion using 89-97 thunderbird or cougar parts
lots of Info on air ride simple search
+1
Air ride is much nicer than standard suspension but so much cheaper & worry free. Just swap out & never have to worry again... Unless you plan on keeping your car for another 10 years. :)
i have a 95 lincoln mark viii base andwhen im driving my car the air ride drop it gose back up but i tried of fixing the problems please help
Okay, first, use some punctuation :D Next, your air ride will drop about an inch when the car reaches 55mph. Once the speed drops below 45mph, the compressor will kick in and raise it back up to its previous ride height. According to your sentence structure, this sounds like what's happening. Now, if your car drops to the ground over night and has to pump back up in the morning, then you have leaky air springs. A little more detail would be appreciated. :)
I hope he does not mean the normal highway drop and the town pump back up.
That's what I'm thinking.
