Same rant, different story, I hate Ford dealers
Kumba
Tampa
Took car to Ford Dealer under warranty. They replaced #7 and #8 coil. They did not replace the plugs since the warranty didn't cover it. Plugs that had 71K-mi. Plugs that might be fowled or worn or otherwise bad. Plugs that Ford calls to be replaced at 75K-mi under maintenance.
Nope, just plugged in the computer, and replaced coil #7 and #8.
To anyone who has worked for Ford, is working for Ford, or thinking of working for Ford, THE DIAGNOSTIC COMPUTER IS NOT A REPLACEMENT FOR YOUR DAMN BRAIN! A trained monkey with a frontal lobotomy and one arm can plug a diagnostic machine into the on-board computer and read codes. Why not ask yourself WHY something has failed, or what contributing factors may have helped it fail!
Remember when you went to a dealer to get work done cause they were the all-knowing masters of your car and would find or diagnose the actual causes of failure not just the failure? Yeah, me neither.
To the ever decreasing few of you who do work for Ford and routinely try to think outside the box I salute you. You are a dying breed. All I ever see over there anymore are glorified parts changers and people who want to sell you oil, brakes, and tires.
... Plugs that Ford calls to be replaced at 75K-mi under maintenance...
I understand your frustration, and I agree that it was silly for them not to replace the spark plugs, but...
Ford does not call for the spark plugs on these cars to be replaced at 75K miles. The service schedule says 100K miles for spark plug replacement.
Warranties never cover scheduled maintenance. (There are service plans that do.)
If your specific extended warranty doesn't cover plug replacement with coils, then the dealer would be giving away the spark plugs for free, and the mechanic would not be paid for the time it took him to replace them.
I completely agree with you. Just to share some things my "certified service technician" has said to me...
Upon asking to pressure test the cooling system to see if there was any leaks he responded...
"Out of the millions of LSs built, they rarely have problems with the plastic parts"
He also refused to stress test the coils and would only refer to the data charts in the diagnostic tool.
I vow to only go to dealers for warranty work. I can get the same level of incompetence at a local mechanic for half the price. Kudos to the dealers that care about service, mine just looks nice.
I've had no good experiences at my local Ford Stealership..charged $160 to drain and refill trans fluid...and when I left it had a new trans leak...then they explained to me how leaks are normal for that mileage (165k) and I should look at some of their new cars...shame on me, never again
At least at the local mechanic, if I tell him to do something due to me unable to do it myself, it gets done or he don't get paid.
I've never had much done at the Ford shop, I will go get some info or parts, but that's it.
Never had a car/truck that had a warranty.
Thinking like this is why I simply replaced all of the coils and plugs on the LS I purchased myself rather than deal with multiple failure and trips to the dealer as they replaced failing coils 1 at a time.
Except that the Ford TSB for diagnosing bad coils says to pull the plug and inspect it for damage. They never pulled any of the plugs cause "Plug replacement wasn't covered under warranty". I would have GLADLY payed the scandalously gouged price of $9 for a spark plug if they had called me. The only time they called was to say it was done. Then the service writer just kept saying "it wasn't covered under warranty". He did offer to charge me $85 to take everything back apart and put two new plugs in. yay. About 10K miles ago they changed a different coil and called to ask me if I wanted a plug while they were in there. $9 later it was done and I was happy. No clue why they couldn't do that again.
The only good thing I can say is that they replaced two coils this time. So at least my $100 deductible covers parts cost on two OEM coils and I didn't have to put them in. So 3 out of 8 were changed. Going to buy 5 more coils and 8 plugs and just take care of it all. I know #7 and #8 are new, so hopefully it will be obvious which one the third coil is when I replace them.
Yeah, they tried to tell me there was no stress test. Just the onboard computer test and a resistance test with a multi-meter. I tried to explain that Ford did have a stress test for the coils but they weren't having it. Here is a youtube video with a retarded text to speech voice explaining the ACTUAL Ford TSB for stress testing coils. According to my dealer this is all make believe: Ford F150 Coil On Plug Stress Test - YouTube
It's a matter of wanting to do it not able to do it. This is the first car I've ever had a warranty on as well. When I was buying it I kept thinking to myself how nice it would be to just throw it at the dealer whenever it hiccups and driving it fat dumb and happy. All I've found out is that I still haven't broken even on what I paid for the warranty and it's just been such a nightmare to get the damn dealer to actually diagnose anything that doesn't involve the computer spitting out a code. I fought with them for 3 months, went through 2 dealers, and they kept trying to sell me tires for a vibration that ended up being a failing wheel bearing. I took it to a dealer for the brakes when they were squealing and they said that they couldn't find anything wrong and wanted to sell me everything from the knuckle outwards. I've told them not to mess with the air filter cause it was a K&N and they threw it away and put a factory filter in it. I drop it off for their $40 semi-synth oil change which includes airing the tires, topping off fluids, and other piddly things and they give me the car back with 20-psi in the front left tire.
They pretty much ignore anything I ask them to do and do whatever they want. The sad part is it's almost always wrong the first time around unless it's something they do everyday like oil change or tires. What is even sadder is that this has been my general experience at 3 dealers (2 ford, 1 Linc/Merc). I know there are awesome mechanics that work for dealers, I've met a few. But damn if it isn't mostly people who just change parts.
Bottom line is I'm never going back to them. I've had to fight with them too much to get things worked on. This isn't my first rodeo with them, just the final straw. I'll just go back to my old mechanic that I used on my SHO and other cars whenever there is something I don't feel like doing (like oil changes). This weekend i'm going to go tear apart the storage garage and find my tools. As much as I don't like working on a car that I have to drive daily, it's so much nicer when you know things are being done how you want.
Maybe I'll view this as the appropriate time to buy that Navigator or Explorer i've been thinking about and turn the LS into my weekend warrior. I do have that collection of parts in the garage that would like to be put in. :)
I know where you're coming from. Can't bring myself to buy a new car because of it. If they'd sell me the car minus the cost of the warranty I'd gladly do it and pay my own repairs because then I don't have some idiot monkey screwing around under my hood. I'd rather just do it myself and know that it was done right the first time, even though it's getting harder and harder as the years go by to raise that hood with a tool in my hand.
When I took mine in on the coil issue they checked it out and advised me that the coils had already been replaced under warranty, but the plugs had not been changed. The dealer that did the work was out of Kansas where the car originated according to my local dealer. I just did the plugs myself, took all of an hour. That little screw in the back on the driver's side coil cover that everyone goes on about wasn't even that bad to get at.
I'm so glad I get along with my dealer and they listen to me. They found out after the first time of not listening that I wouldn't be pushed around. They even cut me a deal on parts and charge less than book rate on small stuff.
