Long_Island_LS
Ok, to keep this short I need some advice on what wires will provide the following (I know they exist, because I have searched, but only find little bits here and there). Most of what I have read is from Joegr (not much of a surprise there lol) but im installing my kenwood 7" DD w/o navigation.
Car: 2006 LS w/ Audiophile Package
Wire Colors for radio??
Delayed Turnoff for Factory Radio until door opens and the audio dim feature... but im not 100% what this means by reading below...what is the "RAP", or better yet what harness and wire color? and where should i tap the ash tray bulb to?
...any and all help is much appreciated
Okay, I guess the harness is there anyway. You have the eight speaker system, if you are asked for the conversion harness. (I would agree that it's really four component speakers, but officially it's eight for marketing purposes.)
The eight speaker connections will come from the big connector (four positive and four negative), as well as power, ground, and switched power. You won't need the eight pin connector at all.
Please note that the delayed radio turn off is a feature of the factory headunit, and you will lose that when you go aftermarket. You can get it back by running a wire from the RAP signal that goes to the windows and using that instead of the switched power signal on the big connector.
Also, dimming is a feature of the factory headunit. You'll have to tap into the ashtray bulb signal to dim the aftermarket unit.
